Code Q&A: Emergency Shutdown in Dwelling Units
July 24, 2025
Courtesy of www.MikeHolt.com. Based on the 2023 NEC.
Question: For other than cord-and-plug-connected portable generators, an emergency shutdown device for a dwelling unit shall be located _____ at a readily accessible location.
a) inside the dwelling unit
b) outside the dwelling unit
c) within sight of the generator
d) inside or outside the dwelling unit
See answer below.
Answer: b) outside the dwelling unit
Per Sec. 445.19(C): "For other than cord-and-plug-connected portable generators, an emergency shutdown device shall be located outside the dwelling unit at a readily accessible location."
Mike Holt
