NFPA 70B Overview
Key Highlights
- NFPA 70B covers maintenance requirements for electrical equipment installed per NFPA 70 (NEC), excluding consumer appliances for home use.
- Maintenance professionals should familiarize themselves with NFPA 70B to develop effective maintenance plans and ensure safety compliance.
NFPA 70B is the Standard for Electrical Equipment Maintenance. It applies to the equipment installed per NFPA 70 (the NEC) [NFPA 70B 1.3] and addresses preventive maintenance [1.1]. It does not cover consumer appliances intended primarily for the home [1.3.2].
For the typical maintenance technician, having a copy of this standard isn’t essential. That’s because the typical maintenance technician undergoes training by, uses procedures written by, and performs specific maintenance tasks at intervals decided by, people for whom this standard is written.
For others, having a copy of this standard is essential. Maintenance planners, maintenance managers, maintenance engineers, and CMMS managers need to know this standard. They should know it as thoroughly as a Master Electrician is expected to know the NEC. That is true whether they are in-house maintenance, contract maintenance, or work for specialized firms such as electrical testing firms.
The initial chapters are very short. Then you get to a string of chapters about testing, followed by Chapter 9. This chapter is about maintenance intervals. The main feature of Chapter 9 is Table 9.2.2. This table runs nearly 4 full pages. To use it, you look up the type of asset you are trying to maintain (that’s in the Product column, which is sorted alphabetically). Then you choose the Scope of Work from a list that may vary from only one job (e.g., thermography) to several (e.g., visual inspection, mechanical servicing, electrical testing, etc.). Each of these will have an associated interval. The interval for mechanical servicing of one product may differ from the interval for mechanical servicing for another product.
Chapter 10 pertains to Hazardous Locations. Then starting with Chapter 11, each chapter provides the requirements for a specific type of asset (e.g., power and distribution transformers, busways, lighting, wiring devices, etc.). This series ends with Chapter 36, Stationary Standby Batteries. Chapters 37 and 38 are “reserved” for instrument transformers and control power transformers, respectively.
This is followed by 13 annexes, Annex A through M. These provide detailed information. Three of them (Annex C, D, and E) are devoted to symbols, diagrams, and forms (separately, and in that order). There’s an annex on Reliability Centered Maintenance and another with case histories (it includes black and white photos).
Mark LamendolaMark Lamendola
Related
NFPA , National Fire Protection Association. logo of National Fire Protection Association (NFPA)
