Ultra High-Power Charging and the Test Challenge it Creates
The next wave of electric vehicle infrastructure will not arrive quietly. Charging at 500kW and beyond turns a simple energy transfer into something closer to power engineering at an industrial scale. Fleets will demand it, heavy trucks will rely on it, and commercial transport will measure turnaround time in minutes, not hours. That shift changes the work behind the scenes. A charger designed for this level of power cannot merely function; it must withstand heat, maintain safety margins, speak clearly to every vehicle it meets, and do so without faltering under numerous load conditions.
The industry has not reached that point by chance. We are watching battery chemistry advance faster than policy, cable engineering evolve under strain, and standards groups sketch the framework for systems most people have yet to see in the wild. The future feels closer than it looks.
What follows is not a technical manifesto, nor a speculative leap. It is simply a look at how charging changes once power crosses above the half-megawatt range, and what the testing community must build before those systems become ordinary.
Where charging changes character
Stand beside a 50kW DC fast charger, and you hear a controlled urgency − cooling fans, contactors, and the steady thrum of power moving into a battery. Now imagine that process is an order of magnitude higher. The physics do not scale neatly. Current climbs, heat rises, insulation ages faster, and any instability becomes visible far sooner. A 500kW charger is not just a faster version of the one we know. It behaves like a completely different class of electrical system.
The market is already preparing for that jump. High-power DC equipment is well established, megawatt charging for long-haul trucks and marine applications is moving through standards development, and ultra-high-power charging occupies the space between the two. Several manufacturers have demonstrated units exceeding 500kW, and battery makers are signalling that vehicles will soon routinely accept these charge rates. If the last decade was about range, the next will be about charge time and charging speed.
It is tempting to assume that higher power brings new and exotic problems. The reality is more nuanced. Many safety fundamentals remain the same, provided voltages remain below the 1,500V threshold that defines low-voltage limits in most global jurisdictions. What changes is the tolerance. Margins narrow. Components work harder. Drift matters more. A tiny calibration flaw that barely registers on a 125kW install can produce a measurable billing error at five or six times the power level.
When more power amplifies everything
There is a phrase we use often in test and measurement work: load reveals truth. High-power charging makes that truth impossible to ignore. Where lower-power testers can verify safety with a light load, ultra-high-power systems demand deeper scrutiny. A charger that maintains performance at 50kW may behave very differently at 600kW. The dynamic range alone becomes a challenge; low, mid, and high points must all be validated to prove linearity. Two-point calibration is no longer enough.
Thermal behaviour is the most visible stress point. Once current levels rise, the system's cooling architecture becomes the real source of reliability. Air cooling, long considered adequate, strains under sustained high-load sessions. Liquid-cooled cabling and components introduce fresh engineering questions: chemical compatibility, material fatigue, leak detection, and field maintainability. An electrician used to isolation tests and ground-fault checks may suddenly find themselves dealing with pumps, fittings, and coolant management.
The technology is not beyond reach. It simply needs test equipment that understands these behaviours without leaving the technician to interpret standards in the field. That expectation is growing rather than shrinking.
The validation gap is widening
Today, extreme-load validation is more complex than it should be. You could test a 600kW charger by rolling out laboratory load banks, but few operators would attempt it outside a controlled environment. The equipment would be large, expensive, hot, and in many cases unsafe for day-to-day field deployment. It proves the point: infrastructure is evolving faster than the tools used to verify it.
A credible test methodology must do three things. It needs to simulate load at multiple points across the power curve, test communication handshakes state-by-state — vehicle detected, negotiation phase, current ramp, taper, and termination — and capture everything in a record that a regulator or maintenance partner can trust. Those steps cannot rely on specialist interpretation and still be practical at scale. If the market scales, test protocols must scale with it.
That is the same principle behind the push for the use of phantom-power techniques. Instead of dissipating massive amounts of real energy through heat and a resistive bank, a phantom system uses precise electronic methods to replicate loading behaviour with far less heat and weight. It allows safe voltage and current control under computer supervision, removing much of the physical risk. For ultra-high-power charging, this approach may be the only practical path for field metrology and maintenance. The equipment is not yet commonplace, but demand for it is already evident.
Safety as the new design constraint
Most conversations about high-power charging begin with speed: ten minutes to 80%, five minutes to get a truck back on the road. But safety is where the real engineering happens. As power increases, insulation must withstand sharper thermal cycling. Connectors face wear not just from use, but from moving coolant, condensation, and the expansion and contraction of materials under load. Isolation-monitoring systems cannot merely detect faults; they must identify and respond quickly enough to prevent failure.
This is not fear talking. It is the sober reality of electrification at scale. Ultra-fast charging works because the risks are understood and managed. The test community will help shape that outcome. Tools must allow technicians to confirm safety without calculation, step through verification in order, and automatically log results. If maintenance requires a manual of equations, operations will stall. Reliable systems are built when complexity is hidden behind a repeatable procedure. In the next phase of infrastructure, maintenance simplification must be tightly coupled with innovation.
From complexity to confidence: rethinking high-power field testing
The future of high-power testing does not lie in bigger equipment. It lies in reducing the burden on the person carrying it and using it. A technician working roadside, in rain or heat, at the edge of a distribution network, cannot stop to decipher firmware states or interpret vaguely documented curves. They need a test sequence that knows the standard, not a standard they must memorize or reference repeatedly.
This mindset mirrors aviation and grid protection practices. Codified tests replace judgment calls. Verification becomes a checklist instead of a puzzle. In ultra-high-power charging, this approach will separate the providers who scale from those who struggle. The new infrastructure only works when field validation is as routine as commissioning a 50kW unit today.
Nothing about this evolution removes the role of expertise. It simply means expertise must travel inside the instrument. "Put the expert in the box" is more than a phrase; it is the only way technicians can keep pace with rising complexity while still delivering fast, thorough, and safe sign-offs.
Two things can be said with reasonable confidence. First, ultra-high-power charging will not remain a niche. Fleets will drive early adoption. New battery chemistries will shorten charge times. Long-haul transport will expect turnaround measured in minutes. Second, the winners of this phase will not be the companies that shout the loudest about power ratings. They will be the ones who make that power practical.
The gap in test capability is both a challenge and an opportunity. Whoever brings reliable, portable, field-ready high-power validation to market will have a large hand in defining the pace of infrastructure rollout, not with spectacle, but with trust. Reliability at this scale will be unforgiving. But it will also be predictable when measured, logged, verified, and maintained.
Ultra high-power charging is not the future. It is the next standard waiting to happen. The companies that treat extreme-load reliability as an engineering discipline instead of an experiment will shape an ecosystem where charging a truck feels as normal as fuelling a car. And when that becomes ordinary, electrification moves from ambition to infrastructure.
This is where the real work begins, making the extraordinary feel routine.
Theo BrillhartTheo Brillhart
Theo Brillhart serves as the Technology Director at Fluke Corporation’s Research and Development division, where, for over 16 years, he has played a pivotal role in advancing innovative technologies. With extensive expertise in high-tech product development and growth acceleration, Theo leads a team of Senior and Principal Engineers focused on technology exploration, new product creation, and the establishment of global industry standards.
He has been deeply involved in developing international standards, collaborating with prominent organizations such as IEEE, SCTE, the Ethernet Alliance, SAE, and CharIN, while also making significant contributions to global standards through his involvement in multiple ISO and IEC technical committees.
Related
Each of the 16 chargers at the Schneider National Operations Center can refuel two heavy-duty trucks at the same time.
