National Fire Safety Month: Fire Prevention and Risk Reduction in the Electrical Industry
Learn common causes of electrical fires, prevention tactics, and risk-reduction strategies in honor of National Fire Safety Month in October.
Key Takeaways
  • October is National Fire Safety Month, which is dedicated to raising awareness about the causes of fires and how to prevent them.
  • Electrical hazards pose great threats when it comes to causing electrical fires. Knowing these hazards can help prevent accidents.
  • There are several strategies electrical professionals can take to prevent electrical fires, reduce risk, and build a culture of fire safety.
October is National Fire Safety Month, a time dedicated to raising awareness about the causes of fires and the critical steps we can take to prevent them. Within the electrical industry, fire prevention is especially important, as electrical failures and malfunctions remain one of the leading causes of workplace and building fires. By reinforcing safe practices and risk-reduction strategies, we can protect lives, property, and business continuity.
Common electrical fire hazards
Understanding the primary causes of electrical fires is the first step toward prevention. Common risks in our industry include:
  • Overloaded circuits and panels: Exceeding capacity can overheat wiring and equipment.
  • Faulty or damaged wiring: Degraded insulation, cuts, or improper splices increase ignition risk.
  • Improperly maintained equipment: Lack of inspection or worn components can create hidden hazards.
  • Arc flash and arc faults: Sudden discharges of electrical energy can result in sparks and fire.
  • Poor housekeeping: Storing combustible materials near electrical equipment increases fire risk.
Fire prevention techniques for electrical work
Proactive prevention measures should be built into daily operations. Best practices include:
  • Strict adherence to NFPA 70E and NEC standards: Ensures compliant installations and safe system performance.
  • Regular inspections and testing: Identify overheating conductors, loose connections, and insulation failures before they escalate.
  • Load management: Confirm circuits and panels are not overloaded; use proper breakers and protective devices.
  • Routine equipment maintenance: Keep switchgear, transformers, and panels clean, lubricated, and free of dust or debris.
  • Use of certified materials: Only install UL-listed cables, connectors, and devices rated for the environment.
Risk-reduction strategies on the job site
Beyond prevention, every crew member plays a role in reducing fire risks while working:
  • Job hazard analysis (JHA): Complete a JHA before each task to identify potential fire hazards.
  • Hot work permits: Ensure proper authorization and a fire watch are in place for welding, cutting, or grinding near electrical systems.
  • Good housekeeping: Maintain clean, organized work areas and keep flammable materials away from energized equipment.
  • Emergency readiness: Confirm fire extinguishers are accessible, employees are trained, and exit routes are clear.
  • PPE and arc-rated gear: Always wear appropriate protective equipment to reduce ignition potential in case of electrical incidents.
Building a culture of fire safety
Preventing fires in the electrical industry isn’t just about following code — it’s about creating a culture of safety. This includes:
  • Leadership commitment to safe work practices and providing the right tools.
  • Employee empowerment to speak up and stop unsafe work.
  • Ongoing training to ensure crews understand evolving codes, standards, and fire risks.
Final thoughts
As we recognize National Fire Safety Month, commit to reinforcing fire prevention and risk-reduction techniques across every project and facility. By combining compliance, training, and vigilance, the electrical industry can significantly reduce fire incidents and protect the well-being of every worker.
Kevin Kolhonen
Kevin Kolhonen
Kevin Kolhonen is an experienced safety professional with a demonstrated history of working in the insurance/safety fields with specialization in the energy, construction, and transportation sectors. Currently, he is the health and safety manager at JM Electrical, a specialized electrical contractor in Greater Boston. As safety manager, Kolhonen is responsible for wide-ranging assignments, including the implementation, management, and maintenance of the company’s safety policies, procedures, compliance plans, and improvement initiatives. He also monitors industry regulations, visits construction sites to ensure the safety of the JME team, and establishes communications with field supervisors and field staff among other stakeholders. A graduate of Salem State University, Kolhonen brings significant experience in employee health and safety, loss prevention, and risk management to his role at JME. You can reach Kevin Kolhonen at [email protected] and learn more about JM Electrical at www.jmelectrical.com.
