NFPA 70E: Annex Marks the Spot — Part 17
Do you know how to safely work with power factor correction capacitors and other capacitors?
The title of Annex R is “Working with Capacitors.” It is easily the largest of the Annexes, consisting of 10 pages covering R.1 through R.17. It covers a lot of ground. Here’s a quick overview.
The introduction explains why capacitors are dangerous (they can store electricity), even when equipped with bleed-off capacitors. Annex R provides detailed guidance on how to properly assess the risks and implement suitable controls.
Section 2 contains the “qualified person” rule. Section 3 provides a detailed explanation of the various electric shock hazards. Section 4 provides a detailed explanation of the various short-circuit hazards. Section 5 provides a detailed explanation of the hazards associated with internal rupture.
Section 6 explains how to perform a risk assessment for capacitors. This includes determining the arc flash and arc blast hazards. It also includes determining the discharge time and developing a written discharge procedure.
Section 7 explains how to determine the electric shock hazard, and section 8 explains how to determine the energy stored in the capacitor. Sections 9 and 10 provide the mathematical method for calculating the arc flash hazard and the arc blast hazard, respectively.
Section 11 explains how to select the appropriate test and grounding method. Among other things, it covers hard grounding and soft grounding and provides Figure R.11.9(a) to illustrate the difference. Table R.11.9 is helpful for selecting the most appropriate method.
Section 12 explains how to determine the capacitor discharge time. Section 13 explains how to establish an electrically safe work condition where capacitors are present. Section 14 covers the storage and disposal of capacitors. Section 15 provides solid advice on labeling.
Then we get to ground sticks, the subject of Section 16. These are designed, constructed, and installed to safely discharge capacitors. They should be tested periodically, and Section 16 provides recommendations. The selection of where they go and how they are connected requires some analysis, and Section 16 provides guidance on that.
Annex R closes with Section 17, which is a list of eight references.
