Avoiding Eye Damage or Vision Loss
Go beyond safety glasses to protect your eyesight.
You may not have noticed any blind electricians where you work, and you can probably guess why.
Wearing safety glasses in the work area is a way to protect your eyes. It’s only one of several ways, however. Safety glasses, even with side shields, are designed to prevent objects you are looking at from flying into your eyes. Safety glasses don’t protect your eyes from:
  • Spray or splash. You need to wear goggles for that.
  • Airborne pollutants and irritants. You need “don’t go in there” for that unless you correctly wear PPE designed to provide a barrier specifically for that purpose (for example, a full face mask with respirator).
  • Your fingers. You can’t keep your fingers clean enough to eliminate the risk of infection, chemical irritants, or mechanical damage if you start rubbing your eyes with your fingers. If you frequently suffer from dry eye, itchy eye, etc., carry a bottle of sterile eye drops and use those to rinse your eyes.
  • Welding arcs. Wear suitable PPE and/or look/stay away.
