Hand Tool Safety, Part 1
Professional-grade tools can make work safer and more accurate
July 17, 2018
Go into the tool section of a typical hardware store, and you’ll find a range of prices for what initially seem like the same tools. One socket set costs $20 more than another one with the same sizes of sockets. Why is that? And why do two screwdrivers the same size vary so much in price?
Take a closer look at the tools. It costs more to make professional grade tools than it does to make consumer grade tools. In addition to such typical upgrades as better quality steel and better finishes, professional grade tools often have features that make the work safer and more accurate. To identify these features, compare the tools with consumer grade versions and/or consult the manufacturer’s literature.
Consumer brands are fine for casual use, but not for daily work. Your first layer of defense is to identify the consumer brands and stay away from them. Then identify the professional brands and select from those.
