• Fall Protection Lanyards
    New line safe for steel and concrete structures
    Jan. 25, 2021
    The new lineup of 6-ft leading edge lanyards from Werner has been tested and approved for use over steel beams, B-Deck, and precast concrete. Each lanyard is made from ¼-inch 7x19 vinyl-coated galvanized aircraft grade steel cable, and rated for a 12-ft free fall for users up to 310 pounds and up to 400 pounds for a 6-ft free fall. Utilizing a DCELL shock pack (a deceleration device used to reduce the fall arrest force), the product also features a snap hook that connects to the user’s harness, which provides an audible signal that the hook is securely fastened. The lanyards are available in four different configurations: single leg with snap hook anchorage connector, twin leg with snap hook anchorage connector, single leg with rebar hook anchorage connector, and twin leg with rebar hook anchorage connector.
    For more information, visit www.wererco.com.
