Transition couplings
½-in. to 2-in. sizes in die-cast zinc 2½-in. to 4-in. sizes in zinc-plated steel Eliminate need to assemble multiple fittings, or mount a box, to transition between raceways
May 20, 2015
Mighty-Merge EMT to FMC/Greenfield transition couplings are available in ½-in. to 2-in. sizes in die-cast zinc and 2½-in. to 4-in. sizes in zinc-plated steel. Designed to eliminate the need to assemble multiple fittings, or mount a box, to transition between raceways, the EMT to FMC fittings (from ½ in. to 2 in. in size) are cULus-listed, while the EMT/Rigid to FMC (from 2½ in. to 4 in. in size) are cETLus-listed.
Bridgeport Fittings
