Battery tester
Designed to test lead acid batteries used in backup systems Chrome model simulates a 20-hr (C20) discharge test in just 6 sec. ACT 612 tests 6V/12V standby SLA, cyclic GEL, and car flooded batteries
The Intelligent battery tester product line is designed to test lead acid batteries commonly used in backup systems. The Chrome model simulates a 20-hr (C20) discharge test in just 6 sec. and displays the VDC and Ah capacity available within 12V SLA batteries between 1.2Ah and 200Ah. The ACT 612 tester is designed for 6V/12V standby SLA, cyclic GEL, and car flooded batteries between 1.2Ah and 100Ah. This model also simulates a 20-hr (C20) discharge test in seconds and displays the VDC and actual Ah capacity available.
ACT Meters
