Arc flash analysis software
Gathers required equipment attributes needed to conduct an arc flash analysis Models equipment relationships using a drag-n-drop interface Produces a report containing the location of each item that requires a label
Jan. 7, 2014
Designed for PCs and tablets with Windows Vista, 7, or 8 operating systems, FlashTrack is a data collection software tool that allows users to gather the required equipment attributes needed to conduct an arc flash analysis. These same attributes can be used to complete a coordination study or short circuit analysis. The software models equipment relationships using a drag-n-drop interface and catalogs the attributes in the format of a single-line diagram. In addition, the product exports the completed files to an Excel file (.xls) or CSV file and produces a “Label Installation Report” containing the location of each item that requires a label to be installed. The report can include up to four photographs per item.
Facility Results
For more information, visit www.facilityresults.com.
