NK Technologies DT Series 3Wire current transducer
Current transducer
Dec. 31, 2013
Compact Uses a common point for power supply and output signal Factory calibrated for a single current range
The DT Series 3-Wire current transducer comes in a compact, space-saving case. The transducer uses a common point for power supply and output signal, and is factory calibrated for a single current range. Featuring industry-standard outputs of 0VDC to 5VDC or 0VDC to 10VDC proportional to the DC current, the unit is powered by 24VDC and is easy to install.
NK Technologies
For more information, visit www.nktechnologies.com.
