• Automatic transfer switch
    Designed for use in critical facilities, such as hospitals, the Zenith Controls ZT30 UL 1008 listed 30-cycle automatic transfer switch (ATS) features a quick-make/quick-break design that enables manual operation with the door closed.
    May 17, 2013
    The Zenith Controls ZT30 UL 1008 listed 30-cycle automatic transfer switch (ATS) helps isolate a fault condition to restrict o
    utages to the equipment affected and maintain power to critical equipment in the rest of the facility. Featuring a quick-make/quick-break design that enables manual operation with the door closed, the ATS includes a shutter door which, when the ATS portion of a bypass switch is being tested or maintained, covers the live bus bars forming a barrier that protects maintenance personnel. Additional features include an interchangeable source cable termination, 100% top or bottom cable entry, and simple field-configurable voltage selection.
    GE Digital Energy
    For more information, visit www.gedigitalenergy.com.
