Electrical design software
Winsta designer assists users with large-scale lighting projects by providing detailed electrical
planning with Winsta components. Based on standard elcoCAD software from Hannappel Software GmbH, the software contains a symbol library designed specifically for Winsta components. Parts lists, cable schedules, cable length calculation, and other reports can be generated for planning evaluation. Available in two versions, one version is a plug-in for elcoCAD and requires AutoCAD LT (Version 2002 or higher) and elcoCAD. The other, a stand-alone version, may be used if elcoCAD is not available; this version only requires AutoCAD LT (Version 2002 or higher).
Wago
For more information, visit www.wago.us.
