Residential EV charger
The Evr-Green 320 Level 2 residential EV charger provides up to 32A at 240VAC (7.7kW output), which the company says reduces the charge time of any SAE J1772-compatible elect
ric vehicle by 7% compared to leading competitors. Features include a durable, weatherproof NEMA Type 4 steel enclosure that installs in a cord-connected installation when used with the company’s Pre-Wire Installation Kit or can be converted to a hard-wired installation, if required. Available with an 18- ft or 25-ft charging cable, the product includes a ground monitor circuit and built-in communication to verify proper connection before charging can commence. An auto-restart feature enables charging to restart following a minor fault.
Leviton
For more information, visit .
