Pneumatic saws
SAWITSD and SAWITD pneumatic saws feature immediate shut down when the throttle is released and immediate start up with throttle squeeze
SAWITSD and SAWITD pneumatic saws feature immediate shut down when the throttle is released and immediate start up with throttle squeeze. With blade variations, the saws cut plastic (including C-900 PVC), steel, and stainless steel with a minimal 6-in. clearance beyond the pipe to accommodate for blade movement. In addition, the tools cut up to 20-in. (500-mm) diameter pipe with a single set-up or larger diameter pipe with optional chain extensions and several clampings. The SAWITSD model includes a trigger lock that prevents accidental “on.”
Reed Mfg. Co.
For more information, visit www.reedmfgco.com/index.html?screen=saw_it_pneumatic_saw.
