Cable ties
Suitable for solar installations, SunBundler cable ties are designed to handle cable bundles from 2.30 in. (58.4 mm) to 4.20 in. (106.7 mm) in diameter
Jan. 23, 2012
Suitable for solar installations, SunBundler cable ties are designed to handle cable bundles from 2.30 in. (58.4 mm) to 4.20 in. (106.7 mm) in diameter. The cable ties are constructed from aircraft-grade stainless wire with a UV-protected vinyl jacket. In addition, the devices feature a tin-plated copper crimp sleeve. Standard wire cutters can be used to crimp the sleeve and cut any excess wire.
Heyco
For more information, visit www.heyco.com.
