Liebert
Rackmount UPS
Feb. 10, 2015
Convertible for rackmount or tower configurations 500VA to 3kVA models include two pairs of individually configurable power outlets Internal ambient temperature sensors now standard on all models
The Liebert GXT4 system is a true on-line, double conversion UPS that's offered in the following sizes: 500VA to 3,000VA at 120V; 3kVA to 10kVA at 208V; and 700VA to 10kVA at 230V. It's convertible for rackmount or tower configuration and includes multiple battery options, with certain models (5kVA to 10kVA) now containing factory-installed batteries. New software allows the predefined system configuration file to be quickly replicated across multiple models of the same size, making it easier to deploy more than one unit. The 500VA to 3kVA models include two pairs of individually configurable power outlets that are controllable and programmable for various settings, such as load shedding or protecting against unauthorized use. Internal ambient temperature sensors also are now standard on all models.
Emerson Network Power
