Code Quiz: Electric Ranges Demand Load Requirement
Based on the 2023 NEC.
Question: What is the maximum demand load required for ten 14kW household electric ranges?
See answer below.
Answer: 27.5 kW
Explanation: : NEC Table 220.55 Column C has a value of 25kW for ten ranges, this value must be increased 10% per note #1 because the 14kW ranges exceed the 12kW rating of column C.
Lupacchino is a senior design engineer with Gaylor Electric, Inc. in Noblesville, Ind. and serves as an alternate on NEC Code-Making Panel No. 3. He is currently licensed in more than 80 jurisdictions. He can be reached at [email protected]
John Lupacchino
Senior Design Engineer
