Code Quiz: NEC Required Unit Load for Office Building Receptacles
Based on the 2023 NEC.
Question: What is the required unit load for receptacles in an office building?
See answer below.
Answer: 180 VA
Explanation: Section 220.44(1) refers you to Sec. 220.14(I), which specifies 180 VA per yoke and then the demand factors of Table 220.47 can be applied. Section 220.43(2) requires 1VA/sq. ft. The larger of these values is required to be used.
Lupacchino is a senior design engineer with Gaylor Electric, Inc. in Noblesville, Ind. and serves as an alternate on NEC Code-Making Panel No. 3. He is currently licensed in more than 80 jurisdictions. He can be reached at [email protected]
John Lupacchino
Senior Design Engineer
