Code Quiz: NEC Requirement Regarding Electrical Equipment Rooms
Based on the 2023 NEC.
Question: When is panic or listed fire exit hardware required for electrical equipment rooms?
See answer below.
Answer: When the equipment is 800A or more and the personnel doors are with 25 ft of the equipment.
Explanation: Section 110.26(C)(3) states, "Where equipment rated 800A or more that contains overcurrent devices, switching devices, or control devices is installed and there is a personnel door(s) intended for entrance to and egress from the working space less than 25 ft from the nearest edge of the working space, the door(s) shall open at least 90 degrees in the direction of the egress and be equipped with listed panic hardware or listed fire exit hardware."
Lupacchino is a senior design engineer with Gaylor Electric, Inc. in Noblesville, Ind. and serves as an alternate on NEC Code-Making Panel No. 3. He is currently licensed in more than 80 jurisdictions. He can be reached at [email protected]
John Lupacchino
Senior Design Engineer
