Code Quiz: NEC Requirement for Grounding Electrode Conductor
Based on the 2023 NEC.
Question: Is a grounding electrode conductor installed in aluminum rigid conduit required to be bonded to the conduit on both ends?
See answer below.
Answer: No
Explanation: Section 250.64 (E)(1) requires ferrous raceways to be bonded at both ends to the GEC, since aluminum is non-ferrous it would not be required to be bonded at both ends.
Lupacchino is a senior design engineer with Gaylor Electric, Inc. in Noblesville, Ind. and serves as an alternate on NEC Code-Making Panel No. 3. He is currently licensed in more than 80 jurisdictions. He can be reached at [email protected]
John Lupacchino
Senior Design Engineer
