Code Quiz: Dry Type Transformer
Aug. 7, 2025
Based on the 2023 NEC.
Question: What is the largest dry type transformer that may be hung above a drop ceiling?
See answer below.
Answer: 50 kVA
Explanation: As stated by Sec. 450.13 (B), "Dry-type transformers 1,000V, nominal, or less and not exceeding 50 kVA shall be permitted in hollow spaces not permanently closed in by structure."
Lupacchino is a senior design engineer with Gaylor Electric, Inc. in Noblesville, Ind. and serves as an alternate on NEC Code-Making Panel No. 3. He is currently licensed in more than 80 jurisdictions. He can be reached at [email protected]
John Lupacchino
Senior Design Engineer
