Question: When does the room containing electrical distribution equipment require a second entrance / exit?
See answer below.
Answer: When the equipment is rated 1200A or more and is over 6 ft wide.
Explanation: According to the requirements ofSec. 110.26(C)(2), a second entrance is required if the equipment is rated 1200A or more and is over 6 ft wide.
Lupacchino is a senior design engineer with Gaylor Electric, Inc. in Noblesville, Ind. and serves as an alternate on NEC Code-Making Panel No. 3. He is currently licensed in more than 80 jurisdictions. He can be reached at [email protected]
