Question: If the hot and neutral conductors of a feeder are increased in size due to voltage drop is the equipment grounding conductor also required to be increased in size?
See answer below.
Answer: Yes
Explanation: Section 250.122 (B) requires the equipment grounding conductor to be increased in size proportionately to the increase in circular mil area of the ungrounded conductors.
Lupacchino is a senior design engineer with Gaylor Electric, Inc. in Noblesville, Ind. and serves as an alternate on NEC Code-Making Panel No. 3. He is currently licensed in more than 80 jurisdictions. He can be reached at [email protected]
