ID 358617340 © Sugesant93 | Dreamstime.com
67b603f81f4a9dca81fc631c Dreamstime Xl 358617340
Code Quiz: Length Requirement for Bonding Jumpers
Feb. 20, 2025
Based on the 2023 NEC.
Question: Fill in the blank. If installed on the outside, the length of the bonding jumper or conductor or equipment bonding jumper shall not exceed ________ and shall be routed with the raceway or enclosure.
See answer below.
Answer: 6 ft
Explanation: Section 250.102(E)(2) specifies, "If installed on the outside, the length of the bonding jumper or conductor or equipment bonding jumper shall not exceed 6 ft and shall be routed with the raceway or enclosure."
Lupacchino is a senior design engineer with Gaylor Electric, Inc. in Noblesville, Ind. and serves as an alternate on NEC Code-Making Panel No. 3. He is currently licensed in more than 80 jurisdictions. He can be reached at [email protected]
John Lupacchino | Senior Design Engineer
Latest from Quizzes
ID 25002905 © Samiylenko | Dreamstime.com
dreamstime_xl_25002905
ID 367959703 © Suphachai Panyacharoen | Dreamstime.com
dreamstime_xl_367959703
ID 2075878 © Ivan Hafizov | Dreamstime.com
dreamstime_xl_2075878
