ID 66702977 © Nils Ackermann | Dreamstime.com
6759eb87da3f877467ba2882 Dreamstime Xxl 66702977
Code Q&A: PV Equipment Isolating Devices or Equipment Disconnecting Means
Dec. 12, 2024
Courtesy of www.MikeHolt.com. Based on the 2023 NEC.
Question: PV equipment isolating devices or equipment disconnecting means shall be _____.
a) located within the equipment
b) located in sight from and readily accessible from the equipment for those to whom access is required
c) lockable in accordance with Sec. 110.25
d) any of these
See answer below.
Answer: d) any of these
The requirements for PV equipment isolating devices or equipment disconnecting means are found in Sec.690.15(D) of the 2023 NEC.
Mike Holt
Latest from Quizzes
ID 25002905 © Samiylenko | Dreamstime.com
dreamstime_xl_25002905
ID 367959703 © Suphachai Panyacharoen | Dreamstime.com
dreamstime_xl_367959703
ID 2075878 © Ivan Hafizov | Dreamstime.com
dreamstime_xl_2075878
