Question: The length of the box shall not be less than ________ the outside diameter, over sheath, of the largest shielded or lead-covered conductor or cable entering the box.
See answer below.
Answer: 48 times.
Explanation: The answer to this question is found in Sec. 314.71(A) of the NEC. It states, "The length of the box shall not be less than 48 times the outside diameter, over sheath, of the largest shielded or lead-covered conductor or cable entering the box."
Lupacchino is a senior design engineer with Gaylor Electric, Inc. in Noblesville, Ind. and serves as an alternate on NEC Code-Making Panel No. 3. He is currently licensed in more than 80 jurisdictions. He can be reached at [email protected]
John Lupacchino
Senior Design Engineer
