ID 146991764 © Christian Horz | Dreamstime.com
6705548763d00409df7e646c Dreamstime Xxl 146991764
Code Q&A: NEC Requirement for Equipment Grounding When LFNC is Used
Oct. 10, 2024
Courtesy of www.MikeHolt.com. Based on the 2023 NEC.
Question: When LFNC is used, and equipment grounding is required, a separate _____ shall be installed in the conduit.
a) grounding conductor
b) expansion fitting
c) flexible nonmetallic connector
d) grounded conductor
See answer below.
Answer: a) grounding conductor
According to Sec. 356.60, "Where equipment grounding is required, a separate grounding conductor shall be installed in the conduit."
Mike Holt
Latest from Quizzes
ID 8209371 © Indiloo | Dreamstime.com
dreamstime_xl_8209371
ID 136399449 © Stefano Carnevali | Dreamstime.com
dreamstime_xl_136399449
ID 223092987 © Ahmet Yamak | Dreamstime.com
dreamstime_xl_223092987
