ID 8209371 © Indiloo | Dreamstime.com
67e452adf103a497f50b2254 Dreamstime Xl 8209371
Code Q&A: Hydromassage Bathtubs
March 27, 2025
Courtesy of www.MikeHolt.com. Based on the 2023 NEC.
Question: Where installed for hydromassage bathtubs, _____ shall be bonded together.
a) all exposed metal surfaces that are within 5 ft of the inside walls of the tub and not separated from the tub area by a permanent barrier
b) small conductive surfaces such as towel bars and mirror frames
c) double-insulated motors
d) mounting straps or yokes of listed light switches or receptacles
See answer below.
Answer: a) all exposed metal surfaces that are within 5 ft of the inside walls of the tub and not separated from the tub area by a permanent barrier
Section 680.74(A)(4) lists "all exposed metal surfaces that are within 5 ft of the inside walls of the tub and not separated from the tub area by a permanent barrier" as a part that shall be bonded together.
Continue Reading
Latest from Q&A
ID 367959703 © Suphachai Panyacharoen | Dreamstime.com
dreamstime_xl_367959703
ID 57245818 © Mrchan | Dreamstime.com
dreamstime_xl_57245818
ID 360841573 © Kenishirotie | Dreamstime.com
dreamstime_xl_360841573
Most Read
