• Code Q&A: NEC Requirements for Branch-Circuit Conductor Ampacity
    Feb. 8, 2024
    Courtesy of www.MikeHolt.com. Based on the 2023 NEC.
    Question: Branch-circuit conductors supplying a single continuous-duty motor shall have an ampacity not less than _____ rating.
    a) 125% of the motor’s nameplate current
    b) 125% of the motor’s full-load current
    c) 125% of the motor’s full locked-rotor
    d) 80% of the motor’s full-load current
    See answer below.
    Answer: b) 125% of the motor’s full-load current
    According to Sec. 430.22, "Condusctors that supply a single motor used in a continuous duty application shall have an ampacity of not less than 125% of the motor’s full-load current rating."
    Mike Holt
