Code Quiz: Disconnect Switch Cover Requirements for an Air Conditioner Condensing Unit
Based on the 2023 NEC.
Question: Is the cover of a disconnect switch for an air conditioner condensing unit required to be lockable?
See answer below.
Answer: Yes, if opening the cover requires no tools and exposes live parts.
Explanation: In the 2023 NEC, Sec. 440.11 now requires that any disconnect that exposes energized parts when the enclosure is open to either require a tool to open or to be capable of being locked.
Lupacchino is a senior design engineer with Gaylor Electric, Inc. in Noblesville, Ind. and serves as an alternate on NEC Code-Making Panel No. 3. He is currently licensed in more than 80 jurisdictions. He can be reached at [email protected]
John Lupacchino
Senior Design Engineer
