Based on the 2023 NEC.
Question: True or false? A ground clamp that is identified for direct burial may be encased in concrete.
See answer below.
Answer: True
Explanation: A new informational note was added in the 2023 NEC to Sec. 250.70 to make it clear that a ground clamp that is listed for direct burial is alco suitable for encasement in concrete.
Lupacchino is a senior design engineer with Gaylor Electric, Inc. in Noblesville, Ind. and serves as an alternate on NEC Code-Making Panel No. 3. He is currently licensed in more than 80 jurisdictions. He can be reached at [email protected]
