Code Quiz: Grounding Electrode Conductor Installation Requirements
Based on the 2023 NEC.
Question: True or false? It is permissible to install the grounding electrode conductor for a transformer through the ventilation slot on the bottom of the transformer.
See answer below.
Answer: False
Explanation: Section. 250.64(G) prohibits grounding electrode conductors from being installed through ventilation openings. The intent of this requirement is to ensure the vent openings are not restricted.
Lupacchino is a senior design engineer with Gaylor Electric, Inc. in Noblesville, Ind. and serves as an alternate on NEC Code-Making Panel No. 3. He is currently licensed in more than 80 jurisdictions. He can be reached at [email protected]
John Lupacchino
Senior Design Engineer
