© Chernetskaya | Dreamstime.com
Based on the 2023 NEC.
Question: What is the smallest size of copper-clad aluminum wire that may be used for branch circuits?
See answer below.
Answer: #14
Explanation: #14 Copper-clad aluminum was added to Sec. 240.4(D)(3) in the 2023 NEC. It is permitted to be protected at 10A by a branch circuit rated circuit breaker or fuse that is listed and marked for use with #14 copper-clad aluminum wires. The maximum permitted continuous load is 8A.
Lupacchino is a senior design engineer with Gaylor Electric, Inc. in Noblesville, Ind. and serves as an alternate on NEC Code-Making Panel No. 3. He is currently licensed in more than 80 jurisdictions. He can be reached at [email protected]
