Code Quiz: Support Requirements for Conductors in Vertical Raceways
Nov. 17, 2022
Based on the 2020 NEC.
Question: What is the maximum distance required between supports for conductors in a vertical raceway if the conductors are 250kcmil copper?
See answer below.
Answer: 60 ft
Explanation: Section 300.19(A) in the 2020 National Electrical Code (NEC) specifies the maximum intervals for supporting conductors within vertical raceways.
Lupacchino is a senior design engineer with Gaylor Electric, Inc. in Noblesville, Ind. and serves as an alternate on NEC Code-Making Panel No. 3. He is currently licensed in more than 80 jurisdictions. He can be reached at [email protected].
