© May1985 Dreamstime.com
Code Quiz: Threading Requirements for Rigid Metal Conduit
June 15, 2022
Based on the 2020 NEC.
Question: What are the requirements for threading rigid metal conduit in the field?
See answer below.
Answer: All cut ends are to be reamed or finished to remove rough edges, and threads are to be cut with a standard cutting die with a 1 in 16 taper.
Explanation: These requirements are outlined in Sec. 344.28 of the 2020 NEC.
Lupacchino is a senior design engineer with Gaylor Electric, Inc. in Noblesville, Ind. and serves as an alternate on NEC Code-Making Panel No. 3. He is currently licensed in more than 80 jurisdictions. He can be reached at [email protected].
