Based on the 2020 NEC.
Question: True or False? NEC requirements do not apply to wiring installed for temporary power.
See answer below.
Answer: False
Explanation: There is a common misconception that temporary wiring is exempt from the Code, but Sec. 590.2(A) in the 2020 NEC requires temporary wiring to comply with the requirements for permanent wiring unless these requirements are modified by Art. 590.
Lupacchino is a senior design engineer with Gaylor Electric, Inc. in Noblesville, Ind. and serves as an alternate on NEC Code-Making Panel No. 3. He is currently licensed in more than 80 jurisdictions. He can be reached at [email protected].
John Lupacchino
Senior Design Engineer
Related
quiz letters on wooden surface
quiz time
