Code Quiz: Conductor Sizes Permitted in a Raceway
Feb. 16, 2022
Based on the 2020 NEC.
Question: Under normal circumstances, what is the largest size solid conductor that can be installed in a raceway?
See answer below.
Answer: #10
Explanation: As per Sec. 310.3(C) of the 2020 NEC, conductors #8 and larger must be stranded when installed in a raceway.
John Lupacchino
Senior Design Engineer
