• Code Quiz: Pool Pump Motors and GFCI Protection
    Test your NEC knowledge.
    April 15, 2021
    Based on the 2020 NEC.
    Question: Does the NEC require you to add GFCI protection to an existing installation when replacing a pool pump motor?
    See the answer below.
    Answer: Yes
    Explanation: As outlined in Sec. 680.21(D) of the 2020 NEC, "Where a pool pump motor in 680.21(C) is replaced for maintenance or repair, the replacement pump motor shall be provided with ground-fault-circuit-interrupter protection."
    John Lupacchino
    Senior Design Engineer
