Code Quiz: Testing of Swimming Pool Equipment
Test your knowledge of the 2020 NEC.
April 1, 2021
Based on the 2020 NEC.
Question: Can the AHJ require periodic inspections of swimming pools?
 See answer below.
Answer: Yes
Explanation: Section 680.4 was added to the 2020 NEC. It allows the authority having jurisdiction (AHJ) to require periodic inspection and testing of pool equipment.
Lupacchino is a senior design engineer with Gaylor Electric, Inc., in Noblesville, Ind., and serves as an alternate on NEC Code-Making Panel No. 3. He is currently licensed in more than 80 jurisdictions. He can be reached at [email protected].
John Lupacchino
Senior Design Engineer
