Code Q&A: Metal Faceplates for Snap Switches
Courtesy of www.MikeHolt.com. Based on the 2023 NEC.
Question: Metal faceplates for snap switches, including dimmer and similar control switches, shall be connected _____ whether or not a metal faceplate is installed.
a) to the grounded electrode
b) to the equipment grounding conductor
c) to the grounded conductor
d) to the ungrounded conductor
See answer below.
Answer: b) to the equipment grounding conductor
Section 404.9(B) states, "Metal faceplates  shall be connected to an equipment grounding conductor" whether or not a metal faceplate is installed.
Mike Holt
Mike Holt
