Code Q&A: Sealing Type MI Cable Termination Fittings
April 24, 2025
Courtesy of www.MikeHolt.com. Based on the 2023 NEC.
Question: In Class I hazardous locations, sealing compound shall be used in Type MI cable termination fittings to _____.
a) prevent the passage of gas or vapor
b) exclude moisture and other fluids from the cable insulation
c) limit a possible explosion
d) prevent the escape of powder
See answer below.
Answer: b) exclude moisture and other fluids from the cable insulation
Per Sec. 501.15: "Sealing compound shall be used in Type MI cable termination fittings to exclude moisture and other fluids from the cable insulation."
Mike Holt
Mike Holt
