© Nastassia Samal | Dreamstime.com
Dreamstime M 212507835 612689af68204
Code Q&A: Permitted Uses of UF Cable
Aug. 25, 2021
Test your NEC knowledge.
Q. What are the uses permitted by the NEC for Type UF cable?
See answer below.
A. Type UF cable is permitted [Sec. 340.10]:
(1) Underground in accordance with Sec. 300.5.
(2) As a single conductor in a trench or raceway with circuit conductors.
(3) For wiring in wet, dry, or corrosive locations.
(4)  Where installed as nonmetallic-sheathed cable, the installation must comply with Parts II and III of Art. 334. 
Mike Holt
Latest from Q&A
ID 376312510 © Евгений Полишко | Dreamstime.com
dreamstime_xl_376312510
ID 367959703 © Suphachai Panyacharoen | Dreamstime.com
dreamstime_xl_367959703
ID 8209371 © Indiloo | Dreamstime.com
dreamstime_xl_8209371
