Code Q&A: Bushing Requirements
Test your NEC knowledge.
Q. What is the NEC rule for the installation of bushings on rigid metal conduit (RMC)?
See the answer below.
A. To protect conductors from abrasion, a metal or plastic bushing must be installed on conduit threads at terminations, regardless of conductor size, unless the box, fitting, or enclosure is designed to provide this protection [Sec. 344.46].
Informational Note: Conductors 4 AWG and larger that enter an enclosure must be protected from abrasion, during and after installation, by a fitting that provides a smooth, rounded, insulating surface, such as an insulating bushing, unless the design of the box, fitting, or enclosure provides equivalent protection, in accordance with Sec. 300.4(G).
These materials are provided to us by Mike Holt Enterprises in Leesburg, Fla. To view Code training materials offered by this company, visit www.mikeholt.com/code.
Mike Holt
Mike Holt
