Www Ecmweb Com Sites Ecmweb com Files Uploads 2015 01 Ecm Mini Ad 2014
Code Q&A: Boxes at Ceiling-Suspended Fan Outlets
Aug. 23, 2018
What does the NEC require regarding outlet boxes intended to support ceiling paddle fans?
Q. What does the NEC require regarding outlet boxes intended to support ceiling paddle fans?
See the answer below.
This answer is based on the 2017 NEC.
A. Outlet boxes for a ceiling paddle fan must be listed and marked as suitable for the purpose, and must not support a fan weighing more than 70 lbs. Outlet boxes for a ceiling paddle fan that weighs more than 35 lbs must include the maximum weight to be supported in the required marking [314.27(C)].
If the maximum weight isn’t marked on the box, and the fan weighs more than 35 lbs, the fan must be supported independently of the outlet box. Ceiling paddle fans greater than 70 lbs must be supported independently of the outlet box.
Where spare, separately switched, ungrounded conductors are provided to a ceiling‑mounted outlet box, in a location acceptable for a ceiling‑suspended (paddle) fan in one‑family, two‑family, or multifamily dwellings, the outlet box or outlet box system must be listed for the support of a ceiling‑suspended (paddle) fan.
These materials are provided to us by Mike Holt Enterprises in Leesburg, Fla. To view Code training materials offered by this company, visit www.mikeholt.com/code.
Mike Holt
Latest from Q&A
ID 376312510 © Евгений Полишко | Dreamstime.com
dreamstime_xl_376312510
ID 367959703 © Suphachai Panyacharoen | Dreamstime.com
dreamstime_xl_367959703
ID 8209371 © Indiloo | Dreamstime.com
dreamstime_xl_8209371
