Chapter 9 of the NEC — Part 3
Use Table 5 to help calculate the fill percentage.
Suppose you have a mix of various conductors you intend to pull in one raceway. How can you calculate the fill percentage without getting out a micrometer to determine the thickness of each type of conductor? The good news is that there’s an app for that (several apps, actually).
If your phone battery is dead or you don’t have a raceway fill calculator app, but you have a copy of the NEC, there’s still good news. You can use Table 5 in Chapter 9 to find the dimensions of each type of conductor you plan to use. Once you add up the totals for 6 of X conductor, 3 of Y conductor, and so forth, you have the total fill.
Then, you refer to Table 1 of Chapter 9 and see the maximum fill for more than two conductors is 40%. If you take that earlier total and divide it by 40%, you will have the minimum ID for the type of raceway you intend to use. Now, go to Table 4, find your raceway, and see what size you need.
