Motor Maintenance Mojo
Seven tips for keeping things running smoothly.
If you having a hard time keeping up with your motor maintenance obligations, and motors are failing, then give the following tips a try:
  1. Change gearboxes to synthetic gear oil. This can significantly reduce the load on the motor, thus reducing heat. Heat kills motors.
  2. Install automatic insulation resistance testers where practical. These provide early alerts to impending failure and help keep insulation dry.
  3.  Install vibration sensors on or near bearing caps. Alert on an increase from baseline (e.g., 15% increase).
  4.  Install vibration sensors on pedestal and base. Excess vibration here indicates an urgent problem (often easy to fix).
  5. Take motor lubrication seriously. Color-code the lubricant containers by type and apply color-code stickers to each motor. Train lubrication techs so they understand how to choose the correct lubricants, methods, and equipment.
  6.  Schedule ultrasonic analysis of bearings quarterly. When this analysis is done with the right instrument by someone trained in bearing problem detection, you can get several months of advance warning of impending bearing failure.
  7. Check all motors for adequate ventilation and voltage balance.
