© Stevanovicigor | Dreamstime.com
Outsource Dreamstime Xl 87335748 6050a1f1b6c5a
Outsource Infrastructure Maintenance
March 16, 2021
The maintenance department often lacks the specialized equipment, expertise, and data to perform this work.
It is a common practice for the maintenance department to be responsible for the maintenance of both infrastructure and production equipment. It is also a bad practice. The theory behind it: If the maintenance department handles everything, you save money by not using outside services. While you’re at it, task the maintenance department with special projects.
The reality is the maintenance department almost certainly lacks the specialized equipment and expertise to do the infrastructure work well and at the recommended intervals. Something as seemingly simple as a cable maintenance program has much more to it than meets the eye of the casual observer. An electrical testing firm whose techs are certified by industry training bodies can take the program effectiveness from 30% to 99%.
Maintenance also lacks the comparative data to effectively differentiate normal from problematic. Not only does an outsourced power monitoring service have that, they also have accumulated a database of solutions and best practices from (typically) hundreds of facilities.
Bonus: These outside services are usually on a different budget.
Latest from Maintenance, Repair & Operations
ID 84700103 © Tashatuvango | Dreamstime.com
dreamstime_m_84700103
ID 331459991 © Andrei Dzemidzenka | Dreamstime.com
dreamstime_m_331459991
dreamstime_m_188775926_2
