Reducing Costs with your CMMS — Part 1
Change your PM focus to one of intelligent risk reduction.
In many organizations, the cost reduction possible with a CMMS is barely realized. That’s typically because the CMMS is used almost entirely as a direct replacement for a paper work-order process. Instead, think of your CMMS as an asset management tool.
You can use it to understand and balance costs against risks. For example, a particular production line has 37 different PMs. All of these take time to perform, all of them can introduce human error, and many require downtime to be completed. Why not use your CMMS to change your PM locus from one of activity to one of intelligent risk reduction?
Start with risks that are acceptable because the consequences don’t affect safety, the environment, or operations. If you don’t perform PM X, what is the likelihood of Failure Y, and how much would that cost? Use the CMMS to determine the labor cost of PM X. If you deactivate that PM, use the CMMS to track failures that PM X would have prevented.
